Dividing Toolpath
Dividing Toolpath
TK.421
Advisor Advisor
Dividing Toolpath
TK.421
I have a lengthy corner finisher that the cutter broke somewhere in the middle of it. I know where the cutter broke. Is there a way in powermill to select the toolpath segments in cutting order up till that point? I used the divide toolpath by time, but that is a lot of guess work. I'd like to be able to select the area that it broke on, and everything before that.  Seems to me I thought of a way to do this some time ago but have since forgotten.
Any help is appreciated, thanks in advance!
the numbers never lie
rafael.sansao
- Select the last segment;
- Open the reorder form toolpath;
- Shift + select the first item in the list;
- Delete button.
Rafael Sansão
OptiNC - www.optinc.tech
TK.421
That's how i did it before!! Thanks Rafael!!
gosmann.andreas
I have a macro for it if u know the xyz cordinates the tool jumps to that position an u can select the toolpath segment. So its easier to find the right Position
STRING ToolP = INPUT ENTITY TOOLPATH "Choose Toolpath: "
   ACTIVATE TOOLPATH $ToolP
COPY TOOLPATH ;
ACTIVATE TOOLPATH #
RENAME Toolpath ; "WiedereinstiegToolpath"
UNSET TOOLPATHLINKS ;
UNSET TOOLPATHLEADS ;
//Simulation Starten
SIMULATE TOOLPATH ; TOOLBAR SIMULATION RAISE
EDIT PAR 'Simulation.PlayMode' 'points'
// Eingabe Maschinen Nullpunkt
   $SIMULATIONSTATE.MODELLOCATION = INPUT ENTITY WORKPLANE "Choose Workplane: "
// Suche nach Satz
STRING inp = INPUT "Enter the X Y Z coordinates separated by spaces without X Y Z"
STRING ARRAY xyz[] = tokens(inp)
REAL X = real(xyz[0])
REAL Y = real(xyz[1])
REAL Z = real(xyz[2])
SIMULATE JOG ABS X $X Y $Y Z $Z
ROTATE TRANSFORM TOP
FORM TPLIST
