PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Dirname
7 REPLIES 7
Message 1 of 8
john_lute
427 Views, 7 Replies
Dirname
I have a toolpath inside a setup and Im looking for the pathname.
I am able to do this with a toolpath inside a toolpath folder, but I am not able to inside a setup.
STRING folder = dirname(pathname('toolpath',$rev))
7 REPLIES 7
Message 2 of 8
rafael.sansao
in reply to: john_lute
STRING folder = dirname(pathname('setup','1'))
Rafael Sansão
Message 3 of 8
john_lute
Thankyou for the suggestions, but that was not successful.
Here are some examples of my setup and toolpath folders.
In the command window when I type
Next is the toolpath folder example
Im looking for the location of the toolpath. The folder/setup name the toolpath is located in sets up my post options.
Message 4 of 8
rafael.sansao
I'm not sure I understand what you need. This should help you:
STRING $tpName = "1"
IF NOT entity_exists(entity("Toolpath",$tpName)) {
	MESSAGE WARN "Toolpath does not exist"
	MACRO ABORT
STRING $folder = ""
FOREACH set IN FOLDER("Setup") {
	FOREACH ent IN components($set) {
		IF lcase(ent.RootType) == 'toolpath' {
			IF $ent.Name == $tpName {
				$folder = dirname(pathname('setup',$set.Name))
				STRING $msg = "Setup pathname: " + $folder + CRLF + "Setup name: " + $set.Name + CRLF + "Toolpath name: " + $tpName
				MESSAGE INFO $msg
				BREAK
IF $folder == "" {
	$folder = dirname(pathname('Toolpath',$tpName))
	STRING $msg = "Toolpath pathname: " + $folder + CRLF + "Toolpath name: " + $tpName
	MESSAGE INFO $msg
Rafael Sansão
Message 5 of 8
icse
in reply to: rafael.sansao
Why you use the lowercase function in the if statement?
is the root type in some cases different?
Message 6 of 8
john_lute
Thank you for you feedback, but that is not what I'm after.
When I have a toolpath selected using explore select, I need to know which folder the toolpath is located in. Here is the code that works when the toolpath is in a toolpath folder. When I place inside a Setup, the code does not work.
//////////// Explorer Stuff///////////////////////
// Removes selected items from explorer variable
EXPLORER SELECT TOOLPATH ROOT
Macro Pause "Select Desired Toolpaths"
IF is_empty(explorer_selected_entities()) {
Macro Pause "Make sure to select your toolpaths"
// Loops Through Toolpaths
FOREACH item_z IN explorer_selected_entities() {
ACTIVATE Toolpath $item_z
string DIRPath=dirname(pathname(entity('toolpath','')))
Macro Pause $DIRPath
Message 7 of 8
rafael.sansao
Try this:
	STRING $folder = ""
				IF $ent.Name == $item_z.Name {
					STRING $msg = "Setup pathname: " + $folder + CRLF + "Setup name: " + $set.Name + CRLF + "Toolpath name: " + $item_z.Name
					MESSAGE INFO $msg
					BREAK
	IF $folder == "" {
		$folder = dirname(pathname('Toolpath',$item_z.Name))
		STRING $msg = "Toolpath pathname: " + $folder + CRLF + "Toolpath name: " + $item_z.Name
		MESSAGE INFO $msg
@icse
I don't think so (maybe in older versions?). My memory is bad and I copied this excerpt from the manual 😃
Rafael Sansão
Message 8 of 8
john_lute
Thank you, I used a portion of your example to solve my problem.
When you shared your fix on this forum, what method did you use to show the work. Is it and attached Notepad++ Document, or another method.
Here is what I used, thanks again.
string DIRPath = ""
$DIRPath = $set.Name
BREAK
