PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Difference between powerMILL & G Code
10 REPLIES 10
Message 1 of 11
Meysam_Ghorbani
5196 Views, 10 Replies
Hi guys
Why Difference between powerMILL & G Code ?
how can i fix it in post processor?
in 3D model we have a diameter 25 but in gcode 24.999 .
(Horizental machine)
Labels (3)
10 REPLIES 10
Message 2 of 11
Don't you think that 0.001mm is peanuts when you are running it in a machine like that. ??
Message 3 of 11
LasseFred
in reply to: Meysam_Ghorbani
what tolerance do you program with?
______________________
Lasse F.
Message 4 of 11
I know  0.001  mm its not important
but i want to execute exactly 25 mm
Message 5 of 11
Meysam_Ghorbani
in reply to: LasseFred
0.01 mm
Message 6 of 11
LasseFred
You cannot count on your dimension if you run a 0.01 mm tolerance.
you a telling the machine i happy with 25 + -0.01 mm.
try and tighten your tolerance on your toolpath.
Lasse F.
Message 7 of 11
Nobody can answer my question ?!!!!!!
Message 8 of 11
Pijetro
I think LasseFred answered it..
Tighten toolpath tolerance to .001, or .0005....See what happens?
Message 9 of 11
LasseFred
you cannot edit your post processor and get the result you want
Lasse F.
Message 10 of 11
LasseFred
you can either compensate the tool or make a tighter tolerance in P-mill
Lasse F.
Message 11 of 11
i changed <metric decimal places> factor :
Technology Administrators
