im making a macro to create text and i seen something on here about that but it didnt work and anything ive made just breaks.
the macro is supposed to ask what text you want and it creates text at cord 0,0,0 .......... sets the text size and font.
THIS IS WHAT I MADE:
//SELECT A TOOL
string toolSelected = input entity Tool "Choose a tool"
ACTIVATE Tool $toolSelected
CREATE PATTERN ; "ENGRAVING"
EDIT PATTERN ; CURVEEDITOR START
CURVEEDITOR MODE TEXT_HORIZONTAL
MODE POSITION START
MODE POSITION CARTESIAN X "0"
MODE POSITION CARTESIAN Y "0"
MODE POSITION CARTESIAN Z "0"
POSITION APPLY
//FONT SETTINGS
CURVEEDITOR TEXT FONT_SIZE ".125"
CURVEEDITOR TEXT FONT_FACE "Delcam Gothic"
THIS IS WHAT THE OTHER POST HAD:
IF NOT entity_exists('pattern','') {
RETURN
STRING p=entity('pattern','').Name
STRING t=Input 'Text?'
$t='CURVEEDITOR TEXT SET_TEXT "\F \C!4\H ]\S \B \I \U '+$t+'"'
ACTIVATE Pattern $p
EDIT PATTERN $p CURVEEDITOR NOGUI START
MODE COORDINPUT COORDINATES 0 0 0
DoCommand $t
CURVEEDITOR TEXT FINISH
CURVEEDITOR FINISH ACCEPT
from the other post it works untill "DoCommand" then it errors
Solved by icse. Go to Solution.
try this:
string $input = input 'Text:'
string $patternName = 'ENGRAVING'
if entity_exists('pattern',$patternName) {
$patternName = new_entity_name('pattern',$patternName)
create pattern ${patternName}
EDIT PATTERN ${patternName} CURVEEDITOR START
string $cmd = 'CURVEEDITOR TEXT SET_TEXT "\V{1}\F{Delcam Gothic;TT}\C{ffffffff}\H{5}\S{0}\B{0}\I{0}\U{0}' + $input + '"'
DoCommand $cmd
At the risk of asking a silly question, have you tried the Text creator plugin that ships with Powermill, i find its does a good job
Hmmm,
I had this once upon a time but for some reason it seems to have gone, is there a link to this plugin?
Regards Jon K
C:\Program Files\Autodesk\PowerMill 2025\file\plugins\installers\plugins
Alright on my telly , i have attached the delcam fonts i could find on my pc from C:\Windows\Fonts.
Try one of these to see if it helps.
Also note, in case you are not aware, that clicking the 'A' box on the font line toggles between all fonts and single line fonts.
Toggling the 'A' box to single line fonts rectified the issue.
Thanks for the tip!
youre a life saver and a headache saver
@jsweatherbie - this post has been edited due to Community Rules & Etiquette violation.
