PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Create one NC program for various individual Toolpaths
4 REPLIES 4
saliljajoo13
356 Views, 4 Replies
Hi everyone,
I use PowerMill 2023, with the Robot plug in to generate programs. I have generated 4 toolpaths for my component, and I when I write NC code using the software, it writes individual NC programs for each toolpath.
How do I merge it so that the output is just one program.
4 REPLIES 4
cfastNJWK6
in reply to: saliljajoo13
Is this turned on?
If so, turn it off and give it a try.
iamcdn79
You need to create a NC Program and make it active then select the toolpaths you want add and select add to NC Program
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
saliljajoo13
in reply to: cfastNJWK6
No, its not turned on.
But, I checked the NC code, I think there's a main program that calls in Sub Programs.
If you are using the Robot plug in ,then you should  be getting  your nc codes  by using it's postprocessing mechanism.
