Hi everyone,
I use PowerMill 2023, with the Robot plug in to generate programs. I have generated 4 toolpaths for my component, and I when I write NC code using the software, it writes individual NC programs for each toolpath.
How do I merge it so that the output is just one program.
You need to create a NC Program and make it active then select the toolpaths you want add and select add to NC Program
No, its not turned on.
But, I checked the NC code, I think there's a main program that calls in Sub Programs.
If you are using the Robot plug in ,then you should be getting your nc codes by using it's postprocessing mechanism.
