PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Create macro to pick folder and activate it
22 REPLIES 22
Message 1 of 23
iamcdn79
3317 Views, 22 Replies
I am trying to create a macro where there is a prompt dialog that will show all my folders create in my toolpath tree. I want to select a folder in the prompt that is already created and activate it. How can I do that?
I need something like this
STRING LIST $FolderName = INPUT ENTITY MULTIPLE TOOLPATH "Select Folder"
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
22 REPLIES 22
Message 2 of 23
tibor.vekasi
in reply to: iamcdn79
Sample  macro for folder selection:
FUNCTION Main() {
   STRING FolderName=''
   CALL SelectFolder('Toolpath','Please select a toolpath folder',$FolderName)
   IF $FolderName !='' {
      MESSAGE INFO $Foldername+' selected'
   } ELSE {
      MESSAGE INFO 'No folder selected'
FUNCTION SelectFolder(STRING FolderType,STRING Prompt,OUTPUT STRING Result) {
   $Result=''
   STRING LIST ValidFolderNames={'ncprogram','toolpath','tool','boundary','pattern','featureset','featuregroup','workplane','model','stockmodel'}
   IF not member($ValidFolderNames,lcase($FolderType)) {
      MESSAGE ERROR 'Invalid Name!'
      RETURN
   STRING LIST Folders = get_folders($FolderType)
   IF (size($Folders) == 0) {
      RETURN
   $Folders=reverse($Folders)
   STRING LIST F=tokens($Folders[0],'\')
   STRING $cmd='EXPLORER SELECT $F[0] ROOT'
   DoCommand $cmd
   DEBUG EXPLORER KEY RIGHT_RECURSIVE
   FOREACH ff in folders {
      EXPLORER SELECT FOLDER $FF NEW
      DEBUG EXPLORER KEY LEFT
   STRING LIST ShortNames={}
   INT I=length($FolderType)+1
   STRING Space='........................'
   FOREACH item in $Folders {
      $F=tokens($item,'\')
      INT S=size($f)
      IF $S >12 {
         MESSAGE INFO ' Sorry, only 12 sublevlel handled'
         RETURN
      IF $S >2 {
         $F[1]=substring($Space,0,2*($S-2))+$F[size($F)-1]
      INT J= add_last($ShortNames,$F[1])
   INT C=-1
   $C=INPUT CHOICE $ShortNames $Prompt
   IF $C != -1 {
      $Result=$Folders[$C]
      $F=tokens($Folders[$C],'\')
      STRING N=$F[0]
      $i=1
      DO {
         $N=$N+'\'+$F[$i]
         EXPLORER SELECT FOLDER $N NEW
         $i=$i+1
      } WHILE $i < size($F)
      ACTIVATE FOLDER $N
Message 3 of 23
iamcdn79
in reply to: tibor.vekasi
Thanks @tibor.vekasi
Thats alot of lines just to pick a folder to activate.
When I try to add an active toolpath and deactivate the folder only the deactivation works. Any ideas why I can't add an active toolpath?
FUNCTION Main() {
      // MESSAGE INFO $Foldername+' selected'
   } ELSE {
      // MESSAGE INFO 'No folder selected'
   $Result=''
      RETURN
      RETURN
   DoCommand $cmd
      INT S=size($f)
      IF $S >12 {
         RETURN
      IF $S >2 {
   INT C=-1
   IF $C != -1 {
      STRING N=$F[0]
      $i=1
      DO {
         $N=$N+'\'+$F[$i]
         $i=$i+1
      ACTIVATE FOLDER $N
   EDIT FOLDER ; INSERT ; LAST
   DEACTIVATE FOLDER
Windows 11 Pro
Message 4 of 23
urizenYHS3W
// get the list of toolpath folders
STRING LIST folders = get_folders('Toolpath')
// Let user pick one
INT idx = INPUT CHOICE folders "Pick a toolpath folder" // Now activate it
ACTIVATE FOLDER ${folders[idx]}
Message 5 of 23
iamcdn79
in reply to: urizenYHS3W
Thanks @urizenYHS3W
But why can't I insert the active toolpath to the active folder?
Windows 11 Pro
Message 6 of 23
urizenYHS3W
Try this:
STRING act_tp = entity('toolpath','').Name
EDIT FOLDER ; INSERT $act_tp LAST
Message 7 of 23
tibor.vekasi
INCLUDE SelectFolder.INC
FUNCTION Main() {
   IF NOT entity_exists('toolpath','') {
      MESSAGE INFO 'Please select a toolpath'
      RETURN
   STRING Tp=entity('toolpath','').Name
      EDIT FOLDER $FolderName
      INSERT $Tp LAST
Message 8 of 23
tibor.vekasi
sample for toolpath usermenu (MoveTp_mnu.mac 😞
// Sample for Toolpath usermenu (toolpath.xml)
// <button label="Move toolpaths to folder"
// command='MACRO MoveTp_mnu.mac "%s"'
// multiple_selection="allowed"/>
FUNCTION Main(STRING Tp) {
IF ($powermill.Status.MultipleSelection.Total == 0) {
INSERT $Tp LAST
$FolderName=''
CALL ProjectPar('LastTpFolder',$FolderName)
} ELSEIF ($powermill.Status.MultipleSelection.First) {
INSERT $Tp LAST
} ELSEIF (powermill.Status.MultipleSelection.Last) {
CALL ProjectParGET('LastTpFolder',$FolderName)
INSERT $Tp LAST
$FolderName=''
} ELSE {
INSERT $Tp LAST
FUNCTION ProjectPar(STRING par,STRING value) {
STRING IsEx =member(project._keys,$par)
IF ($IsEx == 0) {
edit par create STRING $par
${project[$par]} = $value
FUNCTION ProjectParGET(STRING par,OUTPUT STRING value) {
IF ($IsEx == 0) {
} ELSE {
STRING cmd="$"+"value ="+"$"+ "project."+$par
DoCommand $cmd
Message 9 of 23
iamcdn79
@tibor.vekasi I get a 'call to unknown function' error msg on this line
@urizenYHS3W Thanks, this worked
Windows 11 Pro
Message 10 of 23
tibor.vekasi
The 7.post and 8.post attached zip contains "SelectFolder.INC"
Message 11 of 23
iamcdn79
Thanks! @tibor.vekasi never noticed that
Windows 11 Pro
Message 12 of 23
iamcdn79
@tibor.vekasi Do you know what is controlling the explorer slider to move to the top of the Toolpath tree? When I have a  long list of toolpaths I have to always move the slider to the bottom of the Toolpath tree.
I would prefer that it didn't move at all, is that possible?
Windows 11 Pro
Message 13 of 23
tibor.vekasi
The attached SelectFolder_INC.zip  contains two version of function:
-SelectFolder(STRING FolderType,STRING Prompt,OUTPUT STRING Result)   - The original version
-SelectFolderNA(STRING FolderType,STRING Prompt,OUTPUT STRING Result)  - modified version, without expand/collapse Explorer Tree.
Please overwrite previous version of include file, then replace in macros the function SelectFolder calls with SelectFolderNA
Message 14 of 23
iamcdn79
Perfect @tibor.vekasi
Windows 11 Pro
Message 15 of 23
Mikhail_Voronin
Hi
where I can find the full list of commands for macros?
________________________________________
Mikhail
Message 16 of 23
iamcdn79
in reply to: Mikhail_Voronin
Go to Help->Documentation->Parameters->Reference and Help->Documentation->Parameters->Macro Programming Guide
Windows 11 Pro
Message 17 of 23
Mikhail_Voronin
Thank You
I saw it, but thought that there are other
Mikhail
Message 18 of 23
NanchenO
That's actually the most complete doc available.
You can find some other ones on the former Delcam forum if you're lucky or try to ask here if you are missing one. Someone (and/or Autodesk) could have your answer also.
Olivier
Message 19 of 23
Mikhail_Voronin
in reply to: NanchenO
ask here
how to close dialog box  (query) in a macro (see the attachment)
Mikhail
Message 20 of 23
lbp1976
Try to insert
DIALOGS ERROR OFF
DIALOGS MESSAGE OFF
before
@Mikhail_Voronin wrote:
ask here
