CREATE MACRO TO IMPORT STOCK MODEL
diegoverciano85
Message 1 of 12
diegoverciano85
Due to the wide variety of projects in various situations, we export stock models for other programmers to import if necessary.
Instead of looking in windows explorer, I would like to create a macro where I would type in the name of the project (first 4 digits of the file) and it would list only the files with these conditions where I would choose the one and import it.
Replies (11)
Message 2 of 12
TK.421
try this:
STRING filePath = "C:/Users/David/Desktop/test"
STRING LIST $stockFiles = list_files('files', $filePath, '.stkmd')
STRING fileName = INPUT "Enter File Name"
//create a new list stockNames
STRING LIST $stockNames = {}
FOREACH file IN stockFiles {
     IF position(file, fileName) > -1 {
          INT $Ok = add_last($stockNames, TOKENS($File, "/")[SIZE(TOKENS($File, "/"))-1])
//display desired in pulldown list
INT $C = INPUT CHOICE $stockNames "Select Stock File"
the numbers never lie
Message 3 of 12
diegoverciano85
Message 4 of 12
TK.421
Great! you figured out the error? What was it?
Message 5 of 12
diegoverciano85
I had edited the wrong way. Then I saw the error and fixed it and then it worked. So I edited the response where it said it was wrong to correct. To import the chosen file as a stock model should I insert a command in the macro?
Message 6 of 12
TK.421
sorry, yes. put this at the end of your macro:
IMPORT STOCKMODEL ${$stockFiles[$C]}
Message 7 of 12
diegoverciano85
@TK.421
Now testing the macro at work, I report the following problem. In the list that is created after typing, for example, 1404, I chose the fourth item in this list, but accepting it does not matter this item, but the fourth file in the folder in question (in alphabetical order).
Attached image with the reported error
Message 8 of 12
TK.421
Yes, I see the error in my logic. Give me a few minutes to fix it
Message 9 of 12
TK.421
ok, try this. I cleaned it up a little and added some better comments for you.
//---------- initialize variables: ---------//
// -the filepath of the stock model folder  //
// -a list of all the .stkmd files only     //
// -the file name prefix                    //
// -declare empty variable to hold the path //
STRING stockModelPath = ""
// create a new list for only the
// names with the input prefix
STRING LIST stockNames = {}
// loop through the directory and add
// those to the list
	// if the name contains the prefix, add
	// it to the list
        	INT $Ok = add_last(stockNames, TOKENS(file, "/")[SIZE(TOKENS(file, "/"))-1])
// display desired in pulldown list
INT i = INPUT CHOICE $stockNames "Select Stock File"
// create the file path for the
// selected stock model
$stockModelPath = $filePath + "/" + $stockNames[$i]
// import the stock model
IMPORT STOCKMODEL $stockModelPath
Message 10 of 12
diegoverciano85
Now it's perfect. You are awesome. Thank you very much.
Message 11 of 12
TK.421
great! sorry I messed up earlier, I should've paid more attention when I was testing it.
Message 12 of 12
diegoverciano85
Don't worry, your willingness to help those who are not easy with macros is the most important.
