Create folder within toolpath explorer's folder
karan30782
karan30782
Hi all !
I'm tring to make a macro which will create some folders eg. ROUGH & FINISH in each folder which are already available in toolpath explorer.
Like I have 3 folders named Electrode 01,Electrode 02,Electrode 03.
I need to create ROUGH & FINISH folders in all 3 folders , which I already have.
please have a look on my macro and  point me in right direction.
REAL lengthx = ""
REAL lengthy = ""
REAL lengthz = ""
STRING limits = ""
STRING R = 'ROUGH'
STRING F = 'FINISH'
FOREACH ll IN FOLDER ('LEVEL') {
UNDRAW LEVEL ALL DRAW LEVEL $ll.name
EDIT LEVEL $ll.name SELECT SURFACE
FORM BLOCK
EDIT BLOCK RESETLIMIT "0"
DELETE BLOCK
EDIT BLOCK RESET
DRAW BLOCK
DELETE SCALE
$lengthx = $widget("RoughBlock.LimitFrame.LenX").value
$lengthy = $widget("RoughBlock.LimitFrame.LenY").value
$lengthz = $widget("RoughBlock.LimitFrame.LenZ").value
$limits = $ll.name + " _ " + round($lengthx, 0) + " X " + round($lengthy, 0) + " X " +  round($lengthZ, 0)
BLOCK ACCEPT
IF NOT folder_exists("Toolpath\" + $limits ) {
	CREATE FOLDER "Toolpath" $limits + '\' + '$R'
        CREATE FOLDER "Toolpath" $limits + '\' + '$F'
Thank you !
icse
exchange this:
//you whant to create the subfolder only if the main folder exists(removed the not)
IF folder_exists("Toolpath\" + $limits ) {
	string $path = 'Toolpath\' + $limits
	CREATE FOLDER ${path} ${R}
    CREATE FOLDER ${path} ${S}
karan30782
Not working ..... BRO
icse
can you show me the error message?
karan30782
It doesn't show any error ,but not any folder nor sub folder created.
icse
ah now i see... i thougth the base folders are already existant as you wrote in your original post.
try this then:
REAL lengthx = ""
REAL lengthy = ""
REAL lengthz = ""
STRING limits = ""
STRING R = 'ROUGH'
STRING F = 'FINISH'
	FORM BLOCK
	DELETE BLOCK
	EDIT BLOCK RESET
	DRAW BLOCK
	DELETE SCALE
	BLOCK ACCEPT
	CREATE FOLDER 'Toolpath' ${limits}
		CREATE FOLDER ${path} ${F}
karan30782
It's fantastically working !
Thank you !!
