PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Coordinates issue in a Powermill post processor
2 REPLIES 2
daniele.vigoloU85KT
180 Views, 2 Replies
daniele.vigoloU85KT
Hi to all,
in a postprocessor I found a strange behaviour.
it seems that in writing it takes into account the position of the head defined within the kinematics of the post.
in the end I find the X and Y coordinates translated by the value of the position of the head.
what could it depend on?
Thanks in advance...
Hi to all,
2 REPLIES 2
iamcdn79
Without seeing your post it's hard to say but you may have a parameter called "Machine X" or "WP Machine X" somewhere in your post and it may be getting the values from that.
The way to turn it off would be to set output to tape to never.
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Windows 11 Pro
Jonathan.Artiss-DSI
@daniele.vigoloU85KT
The image at the bottom is only a preview and it doesn't take into consideration the other options you could have active.
Output NC Code, ensure you have TCPC active in the output and confirm the tool tip coordinates inside Powermill using Tool Position and the active output workplane.
Jonathan Artiss
Senior Applications Engineer | DSI
Autodesk Expert Elite member
DSI, Design and Software International Autodesk Gold Partner
Jonathan Artiss
