PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Command to divide steep shallow toolpath
7 REPLIES 7
Message 1 of 8
iamcdn79
244 Views, 7 Replies
Does anyone know if there is a command that divides the steep and shallow portion of the toolpath?
I tried making a steep and shallow boundary but it doesn't fall exactly around the toolpath.
I need to extract both sections of the toolpath and change the order to start from the end.
I can use the Reorder option but that changes the constant-Z portion to start from the bottom and go upwards which I don't want
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
7 REPLIES 7
Message 2 of 8
jianhua.fan
in reply to: iamcdn79
Try one of these commands, and hopefully it works.
edit toolpath <name> extract any_shallow <angle>                                 // at least one segment point is shallow
edit toolpath <name> extract entirely shallow <angle>                           //  all segment points are shallow
edit toolpath <name> extract any_steep <angle>                                       // at least one segment point is steep
edit toolpath <name> extract entirely_steep <angle>                                // all segment points are steep
Jianhua Fan
Message 3 of 8
iamcdn79
in reply to: jianhua.fan
Thanks @jianhua.fan, that is exactly something I am looking for, unfortunately it doesn't work as expected.
It only extracts part of the shallow or steep areas I need when I use the same steep/shallow threshold value used in the toolpath
Windows 11 Pro
Message 4 of 8
jianhua.fan
Try to slightly increase/decrease the angle (1~5 degree), and see whether you can get more segments you want.
Jianhua Fan
Message 5 of 8
iamcdn79
It gets a little better doing that but after +/- 2 degs then it starts to remove slices that I need to keep
Windows 11 Pro
Message 6 of 8
jianhua.fan
It is hard to get the expected segments because of noise in the angle. We may need to add a command to extract a segment with most points lying in/out a range.
Jianhua Fan
Message 7 of 8
iamcdn79
what if i convert the toolpath to a pattern? would their be a similar command like
but for patterns that might give better results?
Windows 11 Pro
Message 8 of 8
jianhua.fan
I think we haven't a similar command for a pattern (because we need the angle from contact normal. The toolpath has but the pattern has not).
Jianhua Fan
