PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Check Verification Progress
17 REPLIES 17
Message 1 of 18
TK.421
2030 Views, 17 Replies
if i am verifying a bunch of toolpaths, is there a means I can have it display in an info box which toolpath is being verified? powermill just sits there for 20 minutes and I have no idea if it is in the middle or near the end.
Second question: I make "holder safe" toolpaths when I calculate them. is there any need to check the tick boxes for 'Verify the tool against the model' in the verification form? Maybe I am doing double work and wasting time?
thanks!
Former Expert Elite Member (not enough participation in all their webinars and other "stuff", even though I beta test and regularly contribute to the betterment of the software and the PowerMill community as a whole)
the numbers never lie
17 REPLIES 17
Message 3 of 18
TK.421
in reply to: rafael.sansao
thanks boss!  i think I have something here but I'm not sure about it. so i select a number of toolpaths to add to an nc program, and then add them one at a time and verify, then toolpath goes into info box so i know it is done. when I add a second toolpath ( and third and fourth, etc...) do the connecting moves between that and the first get checked? The previous toolpath has already been verified - does it do it again?  here's my code:
EDIT NCPROGRAM PREFERENCES MODELLOCATION "G54"
EDIT NCPROGRAM PREFERENCES WORKPLANE "G54"
//select toolpaths for posting
STRING LIST $tps = {}
$tps = INPUT ENTITY MULTIPLE toolpath "Select some toolpaths"
//create NcP
STRING ncName = INPUT "ENTER NAME"
CREATE NCPROGRAM $ncName
INFOBOX NEW "NC Verification Progress"
INFOBOX STYLE "WARNING"
INFOBOX STATE "auto_newline" TRUE
INFOBOX STATE "underline" TRUE
INFOBOX APPEND "Verified Toolpaths:"
INFOBOX STYLE "Normal"
//add Tps tp ncP
FOREACH $Tp IN $tps {
EDIT NCPROGRAM ; APPEND TOOLPATH $Tp
//set verification options & verify
EDIT PAR "entity('ncprogram','').Verification.MachineChecks.VerifyToolpaths" 1
EDIT PAR "entity('ncprogram','').Verification.MachineChecks.CheckConnections" 1
EDIT PAR "entity('ncprogram','').Verification.MachineClearance" .5
NCPVERIFICATION VERIFY
INFOBOX APPEND $Tp INFOBOX STATE "auto_newline" TRUE }
Message 4 of 18
rafael.sansao
in reply to: TK.421
connecting moves between that and the first get checked? YES
The previous toolpath has already been verified - does it do it again? NO
With its method, a few milliseconds longer.
Do not worry. Is good.
You can count the number of toolpaths and show the percentage already checked in INFOBOX. Coolest.
Rafael Sansão
Message 5 of 18
TK.421
ok, obrigado amigo. I have 70 toolpaths going tonight, and i get nervous when I change things in my macros... if you say its good, then i can go home and rest easy Smiley Wink
Message 6 of 18
TK.421
in reply to: TK.421
So, my infobox is functional and gives me what I need to see, but I would like to know if I can make it better. is it possible to get the percent at the bottom of the screen (second picture) to run in the infobox? While that program is being verified, i drag my infobox to a second monitor and work on another session of pmill in the main.  thanks!
Capture1.PNGget this into infoboxget this into infobox
Message 7 of 18
rafael.sansao
in reply to: TK.421
No Unfortunately.
You can do a small calculation and show on INFOBOX.
TOTAL TOOLPATH: 21
% STEP: 100 / 21 = 4.7619
9(TOOLPATH ACTUAL) * 4.7619 = 42.85%
Rafael Sansão
Message 8 of 18
TK.421
that is the coolest, thanks!
Message 9 of 18
Pijetro
in reply to: TK.421
Are you Batch Verifying?
If so, do you have the macro for that?
Message 10 of 18
TK.421
in reply to: Pijetro
sort of. my macro selects a bunch of toolpaths and then posts as 1 nc program or individual. Last night (and this whole week) I've been posting 50+ 3+2 toolpaths in single programs. When it verifies, it can take up to 30-45 minutes. attached is my macro for that. let me know how you change it to suit your needs - just curious.
Message 11 of 18
TK.421
i just remembered, that for posting individually i reference another macro because I am too lazy to type it out. here it is
Message 12 of 18
TK.421
Ok chief, I have added to my infobox to show me the time of each toolpath being verified, and I figured out to put it on a second line. is it possible to clear and update the percent line while adding lines to the bottom?  the INFOBOX CLEAR command clears everything.  Maybe it is not possible?
Message 13 of 18
rafael.sansao
in reply to: TK.421
After "INFOBOX CLEAR", rewrite all content.
	INT count = 1
	INT size = size(tps)
	REAL step = 100/$size
	STRING $TP_text = ""
	//add Tps tp ncP
		EDIT PAR "entity('ncprogram','').Verification.ToolAndModel.VerifyToolpaths" 0
		EDIT PAR "entity('ncprogram','').Verification.ToolAndModel.CheckConnections" 1
		//add name to infobox when done
		REAL percntStep = round($count * $step, 2)
		$TP_text = $TP_text + CRLF + $Tp.name + "   Elapsed time: " + "---variable time---"
		STRING msg = $count + " " + "of" + "  " + $size + CRLF + $percntStep + "%" + CRLF + $TP_text
		INFOBOX CLEAR
		INFOBOX APPEND $msg
		$count = $count + 1
Rafael Sansão
Message 14 of 18
TK.421
Thanks @rafael.sansao, that did it! Unfortunately, I cannot use this. Each time I add a toolpath to the nc program it verifies all the previous toolpaths. if the first toolpath takes 2.5 minutes and I add 5 toolpaths after that, it takes an additional 10 minutes of just rechecking the first toolpath...  Now I will put all toolpaths in nc program first and just check it as a whole.  Do you know off hand if there is a way to track with toolpath(s) has/have been verified if I have a program of many toolpaths? now I'm just left with the bar on the bottom. I will have to dig into this more later. The original reason I started the infobox was to give the operator some idea of how many toolpaths are left to verify in a huge program.
thanks again for your help!
Message 15 of 18
rafael.sansao
in reply to: TK.421
No. Sorry.
Showing on the INFOBOX just what NC Program you are checking is not enough?
Rafael Sansão
Message 16 of 18
TK.421
I am only checking one NC PROGRAM - that program has many toolpaths. I was hoping there was a way to show the user which toolpath it is checking, and also how long each toolpath takes to verify.
I will still use infobox for batch verifying multiple nc programs - but that is not what I am doing here. this was all for one nc program. my sincerest apologies for any misunderstanding.
Message 17 of 18
Ye。xg
in reply to: TK.421
The message box does not display a run message in PowerMill Ultimate 2019
Message 18 of 18
TK.421
in reply to: Ye。xg
@Ye。xg  I'll check that
