PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Check the modeling size (Y size) and if it is larger than 500mm, use G60 Y0. Can you make it output as R90
0 REPLIES 0
Message 1 of 1
Grace.lee167YJP
96 Views, 0 Replies
I have a question about Powermill post process output.
1. Is it possible to print the working computer name, IP address, and toolpath minimum Z value in the PowerMill post process?
2. Check the modeling size (Y size) and if it is larger than 500mm, use G60 Y0. Can you make it output as R90.?
0 REPLIES 0
Technology Administrators
