Check the modeling size (Y size) and if it is larger than 500mm, use G60 Y0. Can you make it output as R90
Grace_lee11
Autodesk Autodesk
Message 1 of 1
Grace_lee11
I have a question about Powermill post process output.
1. Is it possible to print the working computer name, IP address, and toolpath minimum Z value in the PowerMill post process?
2. Check the modeling size (Y size) and if it is larger than 500mm, use G60 Y0. Can you make it output as R90.?
Replies (0)
