how can i check if the entities selected in the explorer are toolpaths or something else?
Solved by rafael.sansao. Go to Solution.
INT $i = size(explorer_selected_entities())
IF $i > 0 {
ENTITY ent = explorer_selected_entities()[0]
IF $ent.RootType == "toolpath" {
MESSAGE INFO "Entity type selected: " + $ent.RootType
} ELSE {
MESSAGE WARN "No entity selected."
Rafael Sansão
Thanks @rafael.sansao
I thought of that too, but I was hoping to do it in one line of code.
you could use the filter function like this:
foreach $tp in filter(explorer_selected_entities(),'this.RootType == "toolpath"') {
//your code
This will filter the explorer selection for toolpahts and if no toolpaths are selected the code in the loop gets skipped anyway so no size check needed.
