Change toolpath speed for Additive Manufacturing process
marcos.diezGKW6P
marcos.diezGKW6P
Dear All,
My question is above to change the toolpath speed in some areas of the toolpath only (in the corners).
Does anyone any idea??
thank you in advanced!
armin.bosnjakN3JE3
Hi Marcos,
I have been using these two options:
Sometimes I select and create new "set" with surfaces where I want to lower Feedrate or the second option is to create boundary and lower it inside boundary.
I think this would work without any problems.
marcos.diezGKW6P
Thank you Armin, i didn´t know that.
now my problem is how I can change the speed in the robot program.
Now I use a postprocessor based on Autodesk white postprocessors. the process speed is asocied to one type of movement.
But the program that I´ve done, has the same speed due it has the same category of movement. I am not able to write in the robot program the MOVE TYPE =2.
thank you everybody!
