Change direction in Nc File
dimko696omr
dimko696omr
Hey,
Is it possible to change the direction of an axis in the NC output file?
When an axis is normally positive it should become negative and vice versa.
In my case I would like to change the Y axis.
For example the post processor writes now: X1000 Y500 Z200 A20 B30 C60
It should be this: X1000 Y-500 Z200 A20 B30 C60
Any help is welcome.
Thanks in advance!
Jaanyaar
It should be done in your option file. Reverse the J direction for Y axis. Or attach your post here to be done by someone.
dimko696omr
Hello, thank you for your answer! It worked!
