PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Carousel on Powermill tool database
2 REPLIES 2
omartiz
405 Views, 2 Replies
Good morning,
Due to a lack of PowerMill ideas page i try to put it here.
i've been a Pmill user for a while now and, with a workshop composed by different machine many time i import from database Always the same tools, but i need to change the tool number because of the different carousel.
It is possible to insert that option on it?
For example Visi have it already.
Labels (1)
2 REPLIES 2
danmic7JH66
in reply to: omartiz
You can use seperate tool database for each machine. I built a startup macro that loads in the different machine tools based on which machine I'm programming for which is another route you could go.
omartiz
in reply to: danmic7JH66
It's a workaround, but temporarly i've used the same solution, but the problem is that you have to load the tools in every database if you want have it everywhere.
Technology Administrators
