cant create choice...?
jsweatherbie
jsweatherbie
it says i cant make an choice list ??? is it because its an entity list or am i using this wrong?
reset localvars
if not entity_exists('featureset',"") {
message info "No Feature-set in session"
return
//Filters for only Drilling Programs
entity list $temp = filter(folder("toolpath\"),'strategy == "drill"')
//dummy list
entity list $Selected = {}
foreach i in $temp {
int f = add_last($Selected, entity('toolpath',''))
string $finalSelection = input choice $Selected ""
foreach i in $Selected {
ACTIVATE TOOLPATH $i
iamcdn79
try this
reset localvars
    return
// Filter for only Drilling toolpaths
entity list $temp = filter(folder('toolpath'), 'strategy == "drill"')
// Build a string list of names for the choice dialog
string list $nameList = {}
foreach $i in $temp {
    int $f = add_last($nameList, $i.Name)
// Select Toolpaths
string $finalSelection = input choice $nameList "Select Toolpaths To Activate"
// Activate the chosen toolpath by name
ACTIVATE TOOLPATH $finalSelection
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
jsweatherbie
this works but im trying to get it to be multiple selection i didnt know if it needed to be an entity list or a string list...
ive tired keeping it an entity but i never seem to get it working...
im trying to get it so when the user gets the list they can select what they want and continue with the macro
rafael.sansao
RESET LOCALVARS
IF NOT entity_exists('featureset',"") {
	MESSAGE INFO "No Feature-set in session"
	RETURN
ENTITY LIST $temp = filter(folder("toolpath\"),'strategy == "drill"')
//dummy list
STRING LIST $Selected = {}
FOREACH i in $temp {
INT f = add_last($Selected, $i.Name)
INT LIST $finalSelection = INPUT CHOICE MULTIPLE $Selected "Select toolpaths"
FOREACH i in $finalSelection {
	ENTITY $tp = entity("Toolpath",$Selected[i])
	ACTIVATE TOOLPATH $tp.Name
Rafael Sansão
OptiNC - www.optinc.tech
jsweatherbie
yes that i was trying to do !
seems like i was missing the integer list!
thank you very much!
