PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Block Type Defined by a Clamp?
3 REPLIES 3
evo80
349 Views, 3 Replies
Good Day,
Is there an underlying reason why you can't create a block from a selected clamp?
3 REPLIES 3
old_snickers
in reply to: evo80
If you e.g. import a vice as clamp, the complete model will be set to ignore (thickness set nr. 17). I did not find a way to get the surfaces out of this group till now. Therefore I import my vices as model and put them into a thickness set which I set to collision with separate radial and axial thicknesses.
You can copy the model (the clamp) and select "paste as new model" from the contextmenu of "Models". This will deliver a new model which can be used for machining or creating your block. But this may be obstructive in futher machining directions.
If there is no other way, you can draw a userdefined boundary from which you can sefine your block.
evo80
in reply to: evo80
Thanks for the reply and info of course.
AlexandrMason1
in reply to: evo80
