PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Automatic verification shank clearance issue
2 REPLIES 2
clifford.gage
183 Views, 2 Replies
Hi I'm having a problem when I am trying to finish areas with a small rad .
The tool I am using is 2mm with a shank of 1.8mm so I have a clearance of 0.1mm each side
But if I have the collision checking on and even have the shank clearance a 0.00, it won't cut past the depth of the cutter.
I need to have the collision checking off, or I have noticed if the shank is 1.6mm, it will work with a shank clearance of 0.06.
bit annoying because I don't want to have to change the shank size because I would like to see what the real tool size doing, is case it will crash somewhere, plus the shank starts to taper so I need that to stop within 0.08mm if the pocket gets deeper.
Collision off:
Collision on:
It thinks it is colliding here:
It clearly isn't:
I've attached the program. I'm thinking I maybe have some setting on somewhere not allowing a shank within 0.16mm or something . But I can't seem to work it out.
Any help would be much appreciated.
Cliff
2 REPLIES 2
The tolerance of the toolpath directly influences the final result.
I suggest decreasing the tolerance to 0.02mm and using 0.04mm for the collision check.
The actual clearance must be greater than the toolpath tolerance.
I have attached the amended project.
Rafael Sansão
Ha brilliant, easy fix then.
Thanks Rafael the Legend Sansao.
