ATTENTION DEVELOPMENT: PMILL-10986 Moving start points causes links.....
glen_h
Message 1 of 12
glen_h
When, oh when will you fix this irritating issue?
What is the issue?
For live 5 toolpaths, if you use from or toward line with a set elevation:
Moving start points causes the links to retract up to the SAFE Z permanently.
Trimming the toolpath causes the links to retract up to the SAFE Z permanently.
The workaround is to use from or toward point, which can be annoying since you find yourself adjusting the height of that point until you get a good non-colliding toolpath.....ANNOYING!
Big thanks to all who contribute!
My opinions are my own and are not intended to reflect yours.
Replies (11)
Message 2 of 12
craig.shipley
Autodesk Support
Autodesk Support
Hi I believe this is fixed, pending release.
Kind Regards
Message 3 of 12
It's really a little hard to understand your problem. Please send picture or project.
Message 4 of 12
M_Hennig
I just sent in a project for this annoying bug.  You cannot force them down to save your life, even turning off gouge checking will not drop them.
Message 5 of 12
Jonathan_Artiss19
@M_Hennig
Is it still happening in the 2020.1 release?
Jonathan Artiss
Senior Applications Engineer | DSI
Autodesk Expert Elite member
DSI, Design and Software International Autodesk Gold Partner
Message 6 of 12
M_Hennig
I happens here,..           Version: 2020.0.2.2020023
I did not realize there was a newer one out.
Message 7 of 12
Jonathan_Artiss19
Supposedly this is fixed in the latest release although I have not tested it yet. The release came out today.
Jonathan Artiss
Message 8 of 12
M_Hennig
I just tried it..  It works as expected in my project.😃
Message 9 of 12
Jonathan_Artiss19
Its working for me also!
There was another bug that would show its head when limiting a toolpath using a towards line or from line that's also fixed 🙂
Jonathan Artiss
Message 10 of 12
M_Hennig
I know it's off topic, and I rip on Autodesk every chance I can, but they deserve praise for fixing the automatic collision avoidance, it's night and day faster!
Message 11 of 12
Jonathan_Artiss19
I agree! Good work on this build!
Jonathan Artiss
Message 12 of 12
M_Hennig
I sent praise too soon, it's not fixed. When editing a tool axis they jump up to the safe height and cannot be forced down with the skim. 😫
