i want ask,, why when i click that,, the tool cannot show..
same issue in other field like in "step in play increment"
What do you mean with "cannot show"?
Do you get an error message or are you missing the drop-down/pull-up menu?
Recently I made the switch from PM15 to PM17 without any problems. Make sure you install the service packs also.
Glenn
thanks for ur answer,, but my windows use windows 10 64bit..
is it no problem?
We are still on Win7 64bit so I don't know.
Maybe @iamcdn79 can help you because he works with Windows 10 64bit.
I don't think it is OS related and should try a reinstall of PM.
@GlennM.MCAM I don't understand his comment about what can't be shown
As far as I understand those dropdown menus don't work (check his screenshot).
You don't know if your clicking on the down arrow?
There should be no problem with your configuration. I see two possibilities:
Or it does not do what you want because you do it wrong -> try to have a look at the docs.
Or your installation is not clean. Try to reinstall PowerMill, including the last service pack and being sure that you have administrative rights.
Olivier
