Announcements
angle asin( real a )
HMC400
HMC400
Hello, I would kindly need some help on a trig function.
This :
real sin ( angle 0 )
that's how it works :
Real angolo = 60
Real Numero = 20
Real Hello = ''
$Hello = $Numero *(sin( $angolo ))
Message Info $Hello
how do i make this work?
thank you
cfastNJWK6
This should get you started:
REAL $angle = 60.
REAL $Numero = 20.
REAL $Hello = $Numero * sin($angle)
STRING $msg = "Answer equals " + string($Hello)
MESSAGE INFO $msg
HMC400
hi sorry if i expressed myself wrong but i wanted to make this work:
angle asin( real a)
I also put a screenshot
thank you
cfastNJWK6
The syntax should be exactly the same as the sin() function.  But the asin() function must have a value between -1 and 1 in the parenthesis.
sin(angle)
asin(Opposite/Hypotenuse)
