Adding time on Setup Sheets
Message 1 of 10
Is there a way to add time on the setup sheet for a toolpath? We have been finding that it has been taking a little longer for some toolpaths. So I know that CAD time isn't going to ever equal real time but is there a way that I can add time?
Replies (9)
Message 2 of 10
rafael.sansao
Cutting time, numeric value in minutes.
NCProgram:
${ncprogram.Statistics.nTotalTime}
Toolpath:
${stoolpath.nCuttingTime}
Rafael Sansão
OptiNC - www.optinc.tech
Message 3 of 10
GlennM.MCAM
Time is very inaccurate.
See topic about this here: https://forums.autodesk.com/t5/powermill-forum/how-accurate-are-the-times-shown-in-toolpath-statisti...
Intel i7 4790 @ 3.60GHz -16GB RAM - Nvidia Quadro K620 - 250GB SSD - Win 7 Pro x64 SP1
PowerMILL Premium 2019.1 - PowerINSPECT Ultimate OMV 2017 SP6
Message 4 of 10
I understand that but higher ups are asking for more realistic cycle times
Message 5 of 10
GlennM.MCAM
I don't think there is a fix that will apply for every machine. Slowing down in corners, tool change time, ... are variables that powermill don't calculate with the toolpath time. I guess you should test some things out for a period of time and see how much percent deviation you have from the calculated time.
Message 6 of 10
We have been keeping track of the times and we have been finding that it has been around 1.5 times the original. Is there any way to multiple the cycle times as well as the total NC program time by 1.5?
Message 7 of 10
TK.421
heres what I use. change the 2.9 to 1.5  it outputs in hours
BOOL err = entity_exists ('ncprogram','')
IF NOT $err {
    STRING ncProg = INPUT ENTITY NCPROGRAM "Select NC Program"
    ACTIVATE NCPROGRAM $ncProg
STRING LIST tpNames = extract(entity('ncprogram','').nctoolpath, 'Name')
INT i = 0
REAL ncTime = 0
GRAPHICS LOCK
FOREACH name IN $tpNames {
    STRING str = $tpNames[i]
    ACTIVATE TOOLPATH $str
    DEACTIVATE TOOLPATH
    REAL nonCutting = $toolpath.Statistics.LeadsAndLinks.Times.Others + $toolpath.Statistics.LeadsAndLinks.Times.Plunge + $toolpath.Statistics.LeadsAndLinks.Times.Ramp + $toolpath.Statistics.LeadsAndLinks.Times.Rapid
    REAL cutting = $toolpath.Statistics.CuttingMoves.Times.Arcs + $toolpath.Statistics.CuttingMoves.Times.Linear
    REAL tpTime = (($nonCutting + $cutting) * 2.9) / 60
    $i = $i + 1
    $ncTime = $ncTime + $tpTime
GRAPHICS UNLOCK
MESSAGE INFO time_to_string($ncTime, "H")
the numbers never lie
Message 8 of 10
Thanks, would I put this into my summary html file to get the setup sheet cycle time to be adjusted?
Message 9 of 10
rui_rita
Hi all
you can use this {Statistics.TotalTime *1.5} for each toolpath or ${time_to_string(project.ntotaltime*1.5,"M")} for all project
Os melhores cumprimentos | Best regards
Rui Rita
________________________________
NEWCAM, Lda.
Message 10 of 10
In Setup Sheet you can use:
{time_to_string(1.5*project.nTotalTime,"M")}                                 for total time
{time_to_string(1.5*stoolpath.nTotalTime, 'M')}                             for NC program time
