A small gripe with NC program safety status
stdpattern
Message 1 of 8
stdpattern
Currently using PowerMill 2022, but I think this has been ongoing. Not saying it's a bug, but I just don't like the behavior.
If you change a tool number, and have already posted the NC program, the green color doesn't change. I would like it to change so it is noticeable that it needs to be written again to update the program with the new tool number.
Anybody else? Am I missing something that I can change?
Replies (7)
Message 2 of 8
Jonathan.Artiss-DSI
Are you changing the tool number in the NC Program? I just tested this in 2023.1 and it changes the icon in the explorer from being Green (written) back to white (new).
I don't recall the old behavior.
Jonathan Artiss
Senior Applications Engineer | DSI
Autodesk Expert Elite member
DSI, Design and Software International Autodesk Gold Partner
Message 3 of 8
stdpattern
No, it would be from changing it in Tools>settings. I just tried three tools, changed their tool number in the settings form, and the icon for the NC programs is still green. I am not rejecting the possibility that I am doing something odd.
Steve
Now, IF I go back and activate each NC program, then they do change to a gray color.
Message 4 of 8
Jonathan.Artiss-DSI
Same thing on my end with the latest version. I've never done it this way and it's defiantly not the way I show and teach people.
Since you can activate the NC Program and everything updates, it's probably a bug.
Jonathan Artiss
Message 5 of 8
stdpattern
I am not opposed to learning, what is you preferred method? I just always thought if I need to change the tool number that I would edit the tool.
At least I know I am not completely crazy
Steve
Message 6 of 8
Jonathan.Artiss-DSI
I make the change inside the NC Program, open the NC program settings > pick the toolpath you need to change and update the new tool number.
Jonathan Artiss
Message 7 of 8
stdpattern
OK, I see what you are doing, but....
That doesn't actually change the tool number in the tool settings, right? So other NC programs that may use that tool will be wrong? I use tools for multiple NC programs.
Edit to clarify.  I am changing the number of the tool, not the tool itself.  So same tool but in a different tool changer location.
Message 8 of 8
Jonathan.Artiss-DSI
You're correct, the tool number won't change in the tool settings.
In this case what you're doing makes sense.
Jonathan Artiss
