Not new to PM, but this part is a little out the ordinary for us, eventhough it's a pretty simple part it's giving me a hard time.
I need to create a 4x toolpath to machine the pocket that wraps around the chamfered corner as shown in the attached pictures.
I've tried all kinds of toolpaths, but none are giving me good results. The two that seem to give best results are Swarf Finishing and Pattern Finishing, but with Pattern I'm using the results of the Swarf toolpath to create a pattern which is then use it as a drive curve.
I'm certain there's a simple resolution, but I can't seem to find it.
I've added the 3D file as ZIP if anyone fancies having a look. If you can offer a bit of knowledge I'd greatly appreciate it.
Thanks in advance
Jon
Solved by rafael.sansao. Go to Solution.
what about a pencil toolpath with lead/lean turned on, and mode set to contact normal? I've done such things for radius surfaces that have sharp corners. or i would also try 2 flat toolpaths and a surface finishing toolpath, again with lead/lean and mode set to contact normal. that way you're able to use flat cutter and get the sharp.
Thanks for the suggestions TK.
The pencil seems to be a reasonable solution, but when I try it the toolpath does calc. Only gives results if the Mode is set to "Vertical" or "PowerMILL 2012 R2"
Breaking the groove up into positional (3+2) toolpaths is a solution, but I'd prefer multiaxis. However, if all else fails that's the way we'll have to go.
What version have you run the pencil solution in? We're still on PMP2015 R2 sp10
Thanks again
i may have done that in 2015r2. we update all the time, so i cannot say for sure. what about using a 'towards curve' method from one of the patterns you've created? you could also create a pattern from the corner of the pocket, offset cutter radius and try embedded pattern finish using lead/lean and contact normal; you may need to deselect gouge check on the main part of the form. If i had more time, I'd look at your project. maybe I'll be able to do that later today
i know multiple toolpaths arent optimal, but if this is a one time deal, better to run 2 or 3 of them than waste time trying to get the perfect multiaxis one.let me know what you come up with!
embedded pattern will work, you just need to offset your curve the cutter radius
@TK.421 wrote:embedded pattern will work, you just need to offset your curve the cutter radius
I tried this, but offsetting the pattern causes it to flatten, then when I drop it back on the angled surface it is distorted. Also, after offsetting the results weren't as good
Thanks though
Profile Finishing! Thanks Rafael, that's the one.
Thanks Rafael and TK for your help
Have a great weekend
