4 axis curve to pattern toolpath
Nikola_Kolev
Nikola_Kolev
Hello guys,
is it possible to create 4 axis toolpath using curve - something like normal 3 axis pattern finishing ?
Greetings4_axis_curve.jpg from Bulgaria !
craig.shipley
Autodesk Support
Autodesk Support
Hi
I can't see the image but to create a 4 axis toolpath change the tool axis to "towards line" and ensure that the line is positioned along the centre of your cylinder and along the X axis (1,0,0).
Hope this helps
Kind Regards
craig.shipley
Autodesk Support
Autodesk Support
Sample file attached
Kind Regards
Nikola_Kolev
thank you very much ! works !!
I have tried all except this 😂
