Tolerance Band
Tolerance Band
適用対象外
882件の閲覧回数
1件の返信
メッセージ1/2
Tolerance Band
適用対象外
I can't find where to turn on the tolerance band in the Cad View. I could do it in 2015PI but have not found in 2018. I can only see in options where to change the colors etc.Tolerance Band.PNG
0 件のいいね
解決済み
883件の閲覧回数
1件の返信
返信 (1)
メッセージ2/2
Richard.stubley
解決済み
Hi Brian,
You can turn the tolerance scale on and off from:
File > Options > Application Options > Display Options > Draw tolerance Scale
Also note, you must be inside a relevant group for the tolerance scale to be active, i.e. inside a surface inspection group or a point cloud group. If you are in the top level of the sequence tree (Definition) then the scale will be hidden.
Please see attached image.
Regards
Richard Stubley
Technical Consultant
Richard Stubley
Product Manager - Fusion Mechanical Design
