@metalurgicaprogreso
It is possible- just about. It's not obvious or easy, and it's a rarely used feature which isn't really documented. I'm not surprised you do not know this!
You need to create Geometric 'Point Cloud Single Point' elements. It's possible to create these from a laser scan point source as before.
The bit that's not obvious is how to create these from dynamic points. If you have some dynamic points, you have to select and copy each one individually. When you have selected a dynamic point, you can paste the values to define the nominal position of the Point Cloud Single Point. You do have to create the surface vector yourself.
It's not obvious or especially convenient, but it's not a big problem in the common cases where the surface vectors are aligned with CAD axes like X+ or Z+.
It's more difficult if you have a more complicated angled surface. In that case you have to select the dynamic point, copy all the values to an editor (like Notepad), and then copy and paste the I J K vectors individually as Cartesian coordinates.
I've attached a video that shows and tries to explain this. I hope it helps.
"I had to lower the "Search Distance" parameter to 0.1 mm, because it would not work otherwise. Is this ok? I could not find any help content regarding this parameter."
The search distance is how far it looks beyond the nominal values for the feature (position and size) to include points for the point cloud. 0.1mm seems low unless the parts are very accurate and the alignment is very repeatable. Are there other features or edges (breaks in the point cloud) nearby? It's probably detecting sharp edges which are dominating the feature evaluation. It may be worth copying and trimming the point cloud to remove edges or features.
Philip Hewitt
Product Manager
