Point Cloud - Point Spacing Setting
mlundstrom
mlundstrom
Is there a way to change the point cloud, point spacing default value in power inspect versions 2021-2024? My issue is that it sets itself to a value of .500” right from the start. If I set it to a value such as .050” and scan my point cloud, it spaces my points out at .050”. The trouble is that when I accept that point could and start another point cloud, that point spacing value is back to .500”. If I hit the “set to defaults” button it makes the value .020”. But again, when you accept that point cloud and start a new point cloud, that value returns to .500”. Power Inspect 2020 doesn’t do this; once I set it to .050”, it stays that way even if I close the program and open it back up. Is there a simple fix or is it in the software?
dmitriy.dolgikh
Hi @mlundstrom,
Thanks for the detailed report! We have found the problem. It appears to only apply if your document is in inches. The team will aim to get it fixed.
Dmitriy
