Custom Action Macro
Custom Action Macro
Custom Action Macro
Hi all. I'm new to programming in general but I'm trying to create a visual basic macro for a custom action that loops through a few probed features that I have in my template.and checks that their Sphericity, Cylindricity, Circularity, or Flatness is not over a pre programmed limit. And then if it is, the macro would pop-up a message box that would inform the operator.
I've looked through the Automation Reference a little bit, and found IFeat_SphereItem that looks like it has PropertySphericity that I may be able to use, but I'm not sure how.
But what I was hoping for was someone that had (or could build) some examples of looping through features and looking at their results, or some guidance in general.
Thanks!
Well, I couldn't figure out flatness and decided I didn't need cylindricity, but here's what I came up with:
Sub CheckMeasures()
	Dim ad : set ad = Application.ActiveDocument
		If ad Is Nothing Then Exit Sub
	Dim am : set am = ad.ActiveMeasure
		If am Is Nothing Then Exit Sub
	Dim ai : set ai = ad.ActiveItem  ' get the current active item
	dim G, i, msg, check, index, list, result, badItems, x
	Set badItems = CreateObject("Scripting.Dictionary")
	index = 0
	for each G in ad.SequenceItems
		if G.itemtype = 36006 then ' Feature Group ItemType
			for each i in G.SequenceItems
				Select Case i.ItemType
					Case PWI_EntityItemType.pwi_ent_Feat_ProbedCircle_
						check = FormatNumber(i.PropertyCircularity.Measured(am), 4)
						if check > 0.010 then
							index = index + 1 : badItems.add index, i
							list = list & vbLF & "Feature: " & i.Name & "     " & vbTab & i.PropertyCircularity.Name & ": " & check
						End if
					Case PWI_EntityItemType.pwi_ent_Feat_Sphere_
						check = FormatNumber(i.PropertySphericity.Measured(am), 4)
							list = list & vbLF & "Feature: " & i.Name & "     " & vbTab & i.PropertySphericity.Name & ": " & check
						end if
				End Select
			next
		end if
	next
	if badItems.Count = 0 then Exit Sub
	msg = "The following " & badItems.Count & " measured features are out of tolerance: " & vbLF
	msg = msg & list & vbLF & vbLF & "Please click OK to reset these items, and re-play all."
	result = MsgBox(msg, 49, "Measure Check")
	if result = 2 then exit sub
	for each x in badItems
		badItems.Item(x).Invalidate(am)
	next
	ad.PlayAll()
End Sub
alexey.zorin
Hello Seth,
You are very good in programming VB-Script macro for PowerInspect!
Here is the list of properties you do need:
pwi_ent_Feat_ProbedCircle_ correspond to PropertyCircularity
pwi_ent_Feat_Sphere_  correspond to PropertySphericity
pwi_ent_Plane_Probed_ correspond to PropertyPlanarity
pwi_ent_Feat_Cylinder_ correspond to PropertyCylindricity
Also The FormatNumber function returns an _expression_ formatted as a number.
It is not a reason to use it in comparison to limit (0.01).
So your macro would be corrected as:
  Dim dCheck
      dCheck = i.PropertyCircularity.Measured(am)
      if  dCheck > 0.010 then
       list = list & vbLF & "Feature: " & i.Name & "     " & vbTab & i.PropertyCircularity.Name & ": " & FormatNumber(dCheck, 4)
      End if
      dCheck = i.PropertySphericity.Measured(am)
       list = list & vbLF & "Feature: " & i.Name & "     " & vbTab & i.PropertySphericity.Name & ": " & FormatNumber(dCheck, 4)
      end if
     Case PWI_EntityItemType.pwi_ent_Plane_Probed_
      dCheck = i.PropertyPlanarity.Measured(am)
       list = list & vbLF & "Feature: " & i.Name & "     " & vbTab & i.PropertyPlanarity.Name & ": " & FormatNumber(dCheck, 4)
      end if
     Case PWI_EntityItemType.pwi_ent_Feat_Cylinder_
      dCheck = i.PropertyCylindricity.Measured(am)
       list = list & vbLF & "Feature: " & i.Name & "     " & vbTab & i.PropertyCylindricity.Name & ": " & FormatNumber(dCheck, 4)
      end if
    End Select
   next
  end if
 next
Hope this modification would works for you.
However I'd suggest to you to use CustomStop item.
It would check any item in a group out of tolerance.
During Play All so PI will stops displaying a message pointing on an item that actually out of tolerance.
Benefit of this method allows you to take in account actual limit values defined for each individual item.
Sample picture attached:
Also it's possible to define each individual items to check.
Please click on the Accept as Solution button if my post solves your issue or answers your question.
Alexey
Alexey.Zorin
Technical Support Specialist
Thank you very much for your suggestions. They are a big help.
