Welcome to the Fusion 360 Community! If you landed on this board, intended for sharing your Tips & Tutorials for Fusion 360, but instead are looking for tips or help from the community or Autodesk, please instead post on one of the following Fusion 360 boards:
Thanks!
Hi @madhellsing, Thank you for reaching out and welcome to the Fusion 360 Community.
Did you just install the app for the first time or recently updated it?
We found an issues with opening files after updating to the recent version from last week and we are working to fix it ASAP.
Can you try to uninstall the app completely and then re-install it from Google Play? This should solve it. If you are still experience issues after doing so, could you please send us a screenshot of the error you are seeing?
Thank you,
Hemi.
Hi @Anonymous, Tapping the keyboard Enter key will highlight the second dimension box to allow you entering a value.
Thank you,
Hemi.
Hi @Anonymous, It's normal. The option to setup your own keyboard shortcuts is on Fusion roadmap, but you can also feel free to post it, or any other suggestion, on the IdeaStation forum: http://forums.autodesk.com/t5/ideastation-request-a-feature-or/idb-p/125
Thank you,
Hemi.
HI brian , I have question about how can import 3d models from another application such zbrush maya ..etc to Fusion ? Or In other words how to convert that geometry into body in Fusion ? I try different ways but it all the same doesn't work! So if you guys can help will be grateful. thank..Oday
Hi
I have just started to learn how to malke 3D models. Im trying to use Autodesk 123D. Is there a forum for this please.
Hi @Anonymous - this is likely what you're looking for: https://support.123dapp.com/hc/en-us
Hi
Thanks for that quick reply.
I keep getting a 404 error for that page using the link.
Im in the UK. Is that the problem.
Hello Sir,
I am Press Tool & Die design engineer....i am having trouble in using Simulation for my die stress testing...its showing me completely bizarre results..please guide me.
for example..lets say my blanking or piercing die works on a 200 tonne power press, how would i do stress testing on my Blanking die using simulation..??
please reply ASAP.
Thank You.
Krunal( Manalee Indusries,India)
Hi Krunal-
Thanks for reaching out. Would you be able to share a few images of the results or the model you are questioning? I will gladly review to see if anything obvious is missing from the setup.
In general, I do have some concerns that you might be running into limitations with the current functionality that is in the Fusion Simulation workspace. First, I assume you are using the Linear Static Stress study type for your analysis. This would limit you to simulating linear material behavior (no permanent deformation) and also assumes small deformations and cannot simulate material cutting.
From the description of your problem, it sounds like in the physical world, you are permanently deforming the material or actually cutting it during your manufacturing process. Is this true?
Mike Smell
Simulation Product Manager for Fusion 360
Dear Sir,
Thank you for your quick response. Yes, in reality i actually remove material from metal sheet. For example, say i have MS sheet of dimesion 50X1000X2mm. I want to
remove a Circle of dia 30mm from the sheet throughout the length. I design the whole die & punches for that & now i want to do stress analysis on my blanking die.
i used static stress analysis.
i can share my die design developed in Solidworks.will it be helpful? If so please share your email id; i will mail it.
Thank you,
Krunal
Hi Krunal,
Please contact me directly, michael.smell@autodesk.com to further this discussion. I would like to take a look at your design and dig deeper into the details of your simulation requirements.
Mike Smell
