For Hangers on the AutoCAD side... we use APL feature to 'Skip item if this Property Set Field is TRUE' to prevent APL adding points automatically in a few cases. Then we have internal program code to add sibling point numbers on Trapeze hangers.
I had spoken with you long time ago about possibility of having APL provide sibling points on trapeze... Was wondering if this might be looked at as a future feature? (try that 3 times fast).
But aside from this... is there a suggestion on how we might provide for sibling point numbers on rod 2nd & 3rd of a trapeze coming out of Revit?
Solved by s.hamel. Go to Solution.
I would be all for it as well!
Is there a white paper out there for best practices on embedding APL points into families and mapping parameters back into the project?
