Dear all,
I'm still facing with point layout issue.
Solved by s.hamel. Go to Solution.
Point Layout works with multiple design products and version years. If one is installed after Point layout has been installed, you will need to launch the application which controls which of these products point layout works with.
Go into your start menu -> All Programs -> Autodesk -> and launch the program pictured below.
This will list all the products currently installed that Point Layout will work with, a check mark will be next to the ones it is already registered for, just check the box next to Revit 2017, hit okay, relaunch Revit 2017, and you should be all set.
Shayne
I upgraded from 2016 to 2017 and it loads only the help tab. Any ideas?
Many thanks,
Miriam
Just hit that Get License option, it will load the full set of functions at that point.
