Point Layout 2024: What's New
Happy to announce the release of Point Layout 2024:
Point layout is now delivered through Autodesk Desktop App/Access or your account portal. Trial version can be found here.
Supported Products:
- AutoCAD 2020-2024 + Verticals
- Revit 2020-2024
- Navisworks Manage and Simulate 2020-2024
Revit:
- Revit 2024 support
- Export points: Add Layer column option exposed. Will use the Codemap for matching description to desired value, same as Include Code column option, but column will be placed after description in the file instead of before.
- Fabrication Run / Pipe / Conduit functions now provide options for offsetting points to the top or bottom of the relevant objects based on their outer Diameter or height
- Family points: When using Import function inside of a Family document, the points created will now have their parameters linked automatically
AutoCAD:
- AutoCAD 2024 & Verticals support
Navisworks:
- Navisworks 2024 support
- Fix Revit project based points discovery for 2023+
General across all Plugins:
- Import from Hilti HPL30 files now supported
- Remove support for 2018/2019 products
Thank you,
Shayne Hamel
Manager, Principal Software Engineering
