Layout Licensing Error 2 : 1
glenn.schmitz
glenn.schmitz
Point layout installed just fine on Revit 2024, but when I select Get License I get this error message. What is the fix for this?
s.hamel
Hey Glen, this problem is occurring for a few others as well, we are investigating it currently.  I'll reach out via PM to gather more information.
Shayne Hamel
Manager, Principal Software Engineering
s.hamel
Just to close this thread out, problem ended up being a generic installer issue and not licensing related (just a side affect).
Shayne Hamel
airiarteHMSA4
Community Visitor
Community Visitor
I'm experiencing a similar issue, mine says: 'NO VALID HOSTS WERE FOUND, OR ALL HOSTS WERE EXPIRED: 0.' I'm trying to use the Revit addon trial, but I already have a license through the AEC Collection
s.hamel
Layout will only give that message if you are set to use BIM 360 Glue licensing and you are not part of any Glue projects.
If you have a subscription license you should turn off that, just launch the pictured stand alone application and uncheck the "Use Bim 360 License" option.  If you are part of a glue project then please let me know what version of Layout your on and desktop product you are using it in.
Shayne Hamel
airiarteHMSA4
Community Visitor
Community Visitor
It worked like magic. Thank you!
wcarpenterD2M3R
How would this work when accessing Point Layout through Revit? The hang occurs when the "Get License" button is used without any further input options given.
