When creating points on Autodesk Fabrication hangers, is it possible to have item custom data field information as the point description and not the item filename?
Solved by s.hamel. Go to Solution.
I have tried that, and it doesn't seem to be working....I noticed there is no check box next to the custom data text box. Perhaps that is why it isn't making that option active?
This Semi works, not sure why but it won't take all of the information from the custom data field. For example the custom data I have written for a sleeve is " EL-SL-07 (1' Long) Dia=10" ". The file name of the same sleeve is "Floor Sleeve" and the diameter is 10". By default the description should report out as " Floor Sleeve [ 10 ] " but when i try and add the custom data the description is being reported as "EL-SL-07 (1' Long Floor Sleeve [ 10 ]"...Is there a character limit?
Seems like the hangers are having the same issues. Take a look at the attached .DWG, you will see a "Sokkia Description" custom data field. Currently, as a work around I made a script that creates these descriptions, and writes it to the ITM filename (to be able to export them as the point description) and to the "Sokkia Description" custom data field. Ideally I would like to only have to write to the custom data field and be able to have that as the description and leave the file name alone.
Unfortunately I am not seeing any custom fields/data on these hangers:
thanks,
Shayne
They are embedded in the Fabrication properties. You may not be able to see them in the Clevis hangers as the items tabs doesn't show you the custom data, but they are there. Check the Item properties of a uni-strut hanger.
Still doesn't show up for me, tells me "Specification Invalid" when I view it, and does not show any of your custom fields:
However, I think the limit is not actually with the # of characters used for the Sokkia Description, but for all custom fields overall when retrieved. If possible I would like you to try something. Can you change the order of custom fields? If so, try moving the Sokkia Description in front of a few of those other custom fields and see if you are then getting the full value of Sokkia description added. Let me know.
Shayne
I changed the order and that seems to help with what we are trying to accomplish. Thank you for your help.
Great news Tony, and I appreciate you coming back and providing an update on this!
Shayne
