I have a user trying to pull our network license of APL, and he's getting an error that states: "Could not load file or assemble 'ClicLicensing, Version=1.0.5900.28116, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified."
Chris, can you please have the user make sure they are updated to the latest version. Can simply have them download the free trial version here, http://www.autodesk.com/products/point-layout/free-trial , and install right over what they currently are using. See if that fixes the issue and we will go from there.
Shayne
I'm having issues installing APL 2017. I downloaded from link above. I have BDSU 2017. When I click on APL in add-in tab in Navisworks manage, I get this:
Also when installing it shows licenisng for 2013-2016 only:
Thanks!!
In regards to the licensing side, for 2017+ you select licensing from within the product due to a change in the background, go ahead and trigger APL from Revit or AutoCAD and you should see this.
However for the Navisworks side, I think you are in a bit of a special case here. Are you using Navisworks with BIM 360 Licensing? If so then APL must also be used with BIM 360 Licensing, go ahead and switch the Licensing mode to BIM 360 for 2013-2016 and then try again.
Shayne
That worked Shayne! I have BIM 360 for Navis and when i changed the license type for APL, it worked. Right now I have a trial and we will need to purchase a license for APL I believe. Can we purchase that as a shared network lciense as there are 3 of us but we would never all need it at once. Thanks again.
