Hello APL Community,
Recently I created a point table using "Create Pt Table" In APL everything works correctly but I notice my units are in inches and not feet. how can I change the units in APL pt table?
Solved by s.hamel. Go to Solution.
Nothing built into APL for the 2017 version that would let you do it, but most likely will be for 2018 release.
In a pinch though, note that it is linking back to an excel file saved with same name and location as your drawing, so you could go edit that file and switch in formulas that convert * 12 on the coordinates.
Hello S.Hamel
thank you for your quick response and what I been doing with my CSV file is save as and simply do a quick multiplier formula and presto it's done. It would be nice to simply change units after the creating Pt table command but will do with what we have. once again thank you for your time.
Salvador.Gomez
