Point Layout Forum
Welcome to Autodesk’s Point Layout Forums. Share your knowledge, ask questions, and explore popular Point Layout topics.
Changing units when creating a Pt Table
2 REPLIES 2
salvador.gomez
420 Views, 2 Replies
Hello APL Community,
Recently I created a point table using "Create Pt Table" In APL everything works correctly but I notice my units are in inches and not feet. how can I change the units in APL pt table?
2 REPLIES 2
s.hamel
in reply to: salvador.gomez
Nothing built into APL for the 2017 version that would let you do it, but most likely will be for 2018 release.
In a pinch though, note that it is linking back to an excel file saved with same name and location as your drawing, so you could go edit that file and switch in formulas that convert * 12 on the coordinates.
Shayne Hamel
Manager, Principal Software Engineering
salvador.gomez
in reply to: s.hamel
Hello S.Hamel
thank you for your quick response and what I been doing with my  CSV file is save as and simply do a quick multiplier formula and presto it's done. It would be nice to simply change units after the creating  Pt table command but will do with what we have. once again thank you for your time.
Salvador.Gomez
