Point Layout Forum
Welcome to Autodesk’s Point Layout Forums. Share your knowledge, ask questions, and explore popular Point Layout topics.
Autodesk Point Layout / Revit 2016 Error
1 REPLY 1
aaron.krovance
305 Views, 1 Reply
I am working in Revit 2016, utilizing nested points inside sleeves and a block-out family that has 4 nested points (1 at each corner).  It was working fine, until a day ago when I tried to export points utilizing APL's points tab.  I now get this error message when I execute a command off the APL tab:
I don't know where my next move is, and this error message is less than useful.  Any help would be greatly appreciated.
Thanks in advance!
Aaron
Tags (2)
1 REPLY 1
s.hamel
in reply to: aaron.krovance
Really wish that error message gave a bit more information. Verify that the project you are in has a valid shared parameters file and that the file itself is not set to read-only. You get to this on the Manage Ribbon -> Shared Parameters button. Create one if one does not already exist. Let me know if that solves the issue.
Shayne
Shayne Hamel
Manager, Principal Software Engineering
