AutoCAD APL points display only the Point Number Attribute as a tag next to the point. I noticed there is an elevation attribute but it is empty? Can this be populated easily?
I would like to hide the point number but display the elevation?
Solved by s.hamel. Go to Solution.
This does work for most point types. Unfortunately not for control points.
Is there a way to display the coordinate/geometry data along with the point label? E.g. have the point's X, Y, and Z data displayed under the point label. Thanks!
There is not for the AutoCAD side. You can add an elevation tag, but that only covers the Z.
You can however use the Create Pt Table to add a listing of coordinates to a Layout view:
I created a point table using architectural fractions - is there a way to change the tolerance of the columns? my guys will laugh at me if i sent them /32" lol
