APL Point import not using Shared coordinate in Revit
Been working on this Revit file for a bit. We have a shared coordinate system that is moved and rotated based on the original Survey. PBP is in a convenient nearby location. when exporting points using the Internal coordinate system they all come out relative to the survey point. And a few months ago i imported a number of site points using NEH and they all came in just fine as well.
So today i bring in a point using the internal coordinate system and its off in space. Quick measurement says its come in relative to the PBP not the shared. Rotation is also accurate.
So i opened point manager and all the points have jumped to PBP vs. shared. But when i export and explicitly choose internal the come out correct. Any idea why the import is not using the Survey point?
To clarify PBP was moved clipped and both points are pinned and on different workset. No evidence of them moving or and unclipped adjustment. Since installing APL2019 the import seems to have changed.
Revit 2018.3
B360
APL2019 1001.2018:622
