I am having an issue with nested APL points losing their information when they are being nested. I have been testing this issue and have not had any success in fixing it, not sure if I am missing something or if this is a limitation of APL.
Example of the issue:
1. Create Family1 with an APL point
2. Nest Family1 in Family2
3. Load Family2 into project
4. Add Tags results in the nested APL points showing up as '?'
5. Modify->Filter does not show any of the '?' points even though they have descriptions added in Family1
Additional example:
1. Create Family1 with APL point
3. Add Tags in Family2
3a. Modify->Filter still does not show anything, but the GTP data is populated in Properties (e.g. GTP_PointNumber_0 is '5000')
4. Load Family2 into project
5. Add Tags results will tag with the point number assigned in Family2, but the number is unable to be changed (e.g. it will always be '5000' and does not show up in Modify->Filter and is not affected by using Renumber)
I've tried testing this in multiple projects with the same results. I am often creating families that have multiple nested layers with arrays that APL points need to be a part of. Is there any way to nest APL points in families without having this issue?
