We currently have 19 PDSU network licenses. We will be looking to buy additional licenses later this year, and will apparently be forced to buy the Product Design Collection. Our reseller, while admittedly not entirely sure how this will work, seems to indicate we will not be able to create a single pool of licenses to share.
Does this mean we will need two license servers? And two deployments pointing at each server? Is there no way to combine PDSU and IC network licenses so that the end user clicking on AutoCAD/Inventor gets a license from whichever is available?
I don't want to have to create two groups of engineers with each group having a unique deployment that points to each license server, that seems dumb. Especially since we'll likely have something like 19 PDSUs and only 2-3 PDCs.
Please help me understand AutoDesk's ultimate wisdom in this matter...
TIA
Solved by felice.s. Go to Solution.
Hi @tglass,
If you have 19 network licenses of PDSU, they are by definition perpetual licenses. You are correct in that you cannot purchase additional perpetual seats of PDSU after July 31 (but you can do so until then if you choose.) But let's say that after July 31, you require additional software licenses and you would like to purchase the PD collection. You will have a choice to either purchase single-user (standalone, dedicated) or multi-user (networked, shareable).
Assuming that you go with addition licenses of multi-user PD collection, then a few things to note:
Hope this helps.
Felice
You're welcome, @tglass. I also found this short AKN article on the topic that specifies the "cascade" order - ie, which license is pulled first when you combine subscription licenses and perpetual licences on a single server.
Felice
