So on 4/4/2016, I purchased the maintenance agreement through my reseller... which in the past, also granted me access to any/all updates during the period of my maintenance plan.
Is it now the case, that I no longer have access to any of the 2017 product releases even though it was previously the case that if a release happened while under maintenance plan?
Is it basically the case, that 2016 is the last update I will ever receive... traditionally, extensions and service packs stop upon the release of a new version. What then is the point of a maintenance plan, if I no longer have access to new releases?
Solved by matthew.d. Go to Solution.
Hello @walker.troy
You asked... "Is it now the case, that I no longer have access to any of the 2017 product releases even though it was previously the case that if a release happened while under maintenance plan?"
No, this is not the case. You have access to any product releases (as well as support and other benefits) that become available during the term of your maintenance plan. This continues to be true as long as you renew your maintenance agreement each year before it expires. This is exactly the point of a maintenance plan... to keep your perpetual asset up to date with access to product updates, service packs, etc. plus all other benefits provided by that plan.
I hope this helps.
Felice
If you are on a Maintenance plan (formerly Subscription) you should get updates and new releases. We're on Maintenance for IDSP and upgraded to 2017 with no problem.
Which product do you have. I know sales of any perpetual licensed except Suites stopped in January and Suites are just ending. I don't know if they were allowed to sell a Maintenance contract for a non-Suite product after January. What does your reseller say?
Allen Jessup
CAD Manager - Designer
I have the Entertainment and Creation Suite, which I believe sales end the last day of this month (July)... However, I see no updates or downloads available for 2017 products.
I contacts and opened a case, and they said I do not have access... even though I clearly have purchased my maintenance plan, which is valid through 4/2017.
There must be some mix-up somewhere.... I'll try contacting my reseller I guess, but I figured if anyone knew best it would be Autodesk 🙂
Yes. Sounds like a mix-up in your account. Autodesk employees do monitor this forum. But the Forums are mainly peer-to-peer support. Your reseller is the best place to begin.
Allen Jessup
I actually purchased the suite a couple versions ago (2014?)... I've been on maintenance since.
I was looking for Maya 2017, didn't find it... I was also looking for the Creation Suite 2017.. didn't find that either.
Hi @walker.troy,
Sorry about the issue. Yes, it should automatically appear in your account when the license becomes available. Since it did not, the team will have to manually create the entitlement. The case was the right thing to do. You should see the product in your account soon.
Thanks, that was the issue.. my reseller appears to have been able to get it all straight now.
