ObjectARX
why the entity can not be closed
7 REPLIES 7
Message 1 of 8
475867377
355 Views, 7 Replies
when i open a entity by write,it return eWasOpenForRead (82).then i open it by read,it success,then i close it ,then i open it by write,it return eWasOpenForRead (82) again.the entity is drawed by me.the code is as follow.why does this happen?
7 REPLIES 7
Message 2 of 8
artc2
in reply to: 475867377
The eWasOpenForRead error when you try to open it for write indicates that it is already open for read by something. An object can be open for read simultaneously up to 256 times. So, when you then open it for read, you are just incrementing the openForRead count. When you then close the object, you are just decrementing the openForRead count which puts the object back to the way it was before you opened it for read - still open for read by something else.
Message 3 of 8
475867377
in reply to: artc2
thank you .but the object is drawed by me .then i read it.there is no one to read it .so it won't up to 256 times.
Message 4 of 8
835700012
may be your object id was open for read already?try to show us the error stats at first time for more detail.
Message 5 of 8
475867377
in reply to: 835700012
when i open a entity by write at first time,it return eWasOpenForRead (82).
Message 6 of 8
ynapeu
If you create the entity, you must close it.
Message 7 of 8
835700012
your entity was opened for read before u open it for write,you must close it first
Message 8 of 8
475867377
i have find the BUG,my mistake.it is a little tough to find it .thank you all !
”Boost
