Why does the function `acedIsMenuGroupLoaded` always return `false`?
zhengyunyang2019
zhengyunyang2019
	virtual AcRx::AppRetCode On_kInitAppMsg (void *pkt)
		AcRx::AppRetCode retCode = AcRxArxApp::On_kInitAppMsg(pkt);
		if (Adesk::kTrue == acedIsMenuGroupLoaded(TEXT("nwheleccoordinationsys")))
			acutPrintf(TEXT("exist\n"));
		return (retCode) ;
	virtual AcRx::AppRetCode On_kUnloadAppMsg (void *pkt)
		AcRx::AppRetCode retCode = AcRxArxApp::On_kUnloadAppMsg(pkt);
		return (retCode) ;
        I am testing the "acedIsMenuGroupLoaded" method, and I have already loaded "nwheleccoordinationsys.cuix". However, I have noticed that in the "On_kInitAppMsg" function, using "acedIsMenuGroupLoaded" always returns true, while in the "On_kUnloadAppMsg" function, using "acedIsMenuGroupLoaded" always returns false.
        Calling acedIsMenuGroupLoaded(TEXT("nwheleccoordinationsys")) anywhere else in the code always returns true,only in On_kUnloadAppMsg does it return false.
        The trigger method for On_kUnloadAppMsg is to directly close CAD.
        I think it would be normal for the call in On_kUnloadAppMsg to also return true, so I’m quite puzzled.
        Can you explain what might be causing this?
zhengyunyang2019
I found the key reason for the problem myself.
If I unload the plugin using APPLOAD, then acedIsMenuGroupLoaded works normally in On_kUnloadAppMsg.
However, if I directly close CAD by clicking the X, it still triggers On_kUnloadAppMsg, but acedIsMenuGroupLoaded fails, possibly because some data has already been cleared.
