Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Why does adding AcDbRegion to AcDbDatabase after booleanOperar return eWrongDatabase?
dziwve67853
dziwve67853
static AcDbRegion* GetRegion(AcGePoint3d cenPt)
	AcDbRegion* pRegion = NULL;
	AcDbCircle* pCircle = new AcDbCircle(cenPt,AcGeVector3d::kZAxis,10);
	AcDbVoidPtrArray curveSegments;curveSegments.append(pCircle);
	AcDbVoidPtrArray regions;
	Acad::ErrorStatus es = AcDbRegion::createFromCurves(curveSegments,regions);
	delete pCircle;pCircle = NULL;
	if(Acad::eOk == es && regions.length()>0)
		AcDbRegion* pTmpRegion = (AcDbRegion*)regions[0];
		if(pTmpRegion)
			pRegion = (AcDbRegion*)pTmpRegion->clone();
	for(int i=0;i<regions.length();++i)
		delete (AcRxObject*)regions[i];
	return pRegion;
static AcDbObjectId PostToModelSpace(AcDbEntity* pEnt,AcDbDatabase *pDb = acdbCurDwg())
	Acad::ErrorStatus es;
	AcDbObjectId entId = AcDbObjectId::kNull;
	AcDbBlockTable * pBlockTable = NULL;
	pEnt->setDatabaseDefaults(pDb);
	es = pDb->getBlockTable(pBlockTable, AcDb::kForRead);
	if (es != Acad::eOk)
		return entId;
	AcDbBlockTableRecord *pBlockTableRecord = NULL;
	es = pBlockTable->getAt(ACDB_MODEL_SPACE, pBlockTableRecord,AcDb::kForWrite);
	pBlockTable->close();
		return entId;
	es = pBlockTableRecord->appendAcDbEntity(entId, pEnt);
	pBlockTableRecord->close();
	pEnt->close();
	return entId;
AcDbRegion* pRegion1 = GetRegion(AcGePoint3d(0,0,0));
AcDbRegion* pRegion2 = GetRegion(AcGePoint3d(10,0,0));
if(pRegion1 && pRegion2)
	es = pRegion1->booleanOper(AcDb::kBoolUnite,pRegion2);
	if(Acad::eOk == es && pRegion2->isNull())
		delete pRegion2;pRegion2 = NULL;
AcDbRegion* pTmp = (AcDbRegion*)pRegion1->clone();
AcDbObjectId id1 = PostToModelSpace(pTmp,acdbCurDwg());
AcDbDatabase* pDb = new AcDbDatabase(true,false);
pRegion1->setDatabaseDefaults(pDb);
AcDbObjectId id2 = PostToModelSpace(pRegion1,pDb);
pDb->saveAs(_T("D:\\Region.dwg"));delete pDb;
return;
id1 is ok.id2 is null;
@tbrammer @daniel_cadext @Alexander.Rivilis
tbrammer
AcDbObject::clone() creates a "shallow copy" of the AcDbObject. So it is not safe to append clones to a different database. Your code works for simple entities like AcDbLine - but I would not recomment to do this anyway.
You should use AcDbDatabase::wblockCloneObjects(..) to copy objects from one DB to another.
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
dziwve67853
These two lines prove that they can be added to the current database normally. Even without these two lines, pRegion1 cannot be added to pDb normally.
tbrammer
Correct. A clone is a clone. It doesn't matter which one you add to the DB.
But since it is a shallow clone, some internal references of the regions point to the same internal data.
So as soon as you add one of the two regions to the database you must delete the second one.
This is what happens when you clone() region 1 and append the clone to the DB :
Region 1 depends on the internal data that is now tied to region2 and the DB.
It makes no difference whether you add region 1 or region 2 to the DB. In both cases you must delete the other region. Some simple entities like AcDbLine don't have references like this. But you can't rely on this.
The safe way is to use deep cloning. This guarantees that all internal data is copied as well.
dziwve67853
I use wblockCloneObjects to do it.It works well.Thank you!
